When using Quick Connect and RDP, can I pass saved credentials and keyboard?
Hey everyone, as the subject states, when I use quick connect to RDP I have to enter my saved credentials and then the keyboard is not passed to the RDP connections.
I have regular RDP connections configured that way but wonder if possible to configure Quick Connect the same way.
Thanks!
I would recommend going in File -> Templates -> Entry templates and configuring an RDP template with your Keyboard configuration and other settings. If your credentials are always the same you could also enter your credentials in that template.
Once that is done, you can select your template in the quick connect ribbon at the top by clicking on the icon. This should make it so you open your session with the specified host combined with the configuration in the template.
If your credentials change, then only put your other configurations in the template and use the Quick Connect prompt instead. It can be found in the "View" ribbon or by pressing Ctrl + Alt + Q.
Let me know if this works for you.
Best Regards,
Michaël Beaudin
