I have no "Record" option in connection settings
Resolved
I have no "Record" option in connection settings, is it because I have free RDM for Windows? I wanna record my RDP and SSH sessions
Unfortunately, the session recording feature is not available in the free version of RDM.
As a workaround, you can use the Local Recorder option located under the Help ribbon menu.
Please let me know if you need any further clarification.
Jacob Lafrenière
Thanks, where is located recorded videos?
Thank you for the follow-up.
You can find the path under Files > Settings > Application > Paths.
You can also change it to the desired path!
Jacob Lafrenière
