Delinia PAM (Thycotic Centrify) SSH Connector Problem
We have a problem to connect ssh connection via RDM.
rdm version 2024.3.11.0 also tried 2025.1.16
In putty, we configure like this, when we entered to session, it asks a login name like in Picture2 and we successfully logon the systems.
Can you help me?
In RDM we have a unexpected error (Picture7) and our configuration like Picture4-5-6
All Comments (5)
Can you configure the logs in the "Logs" tab of your entry, run the session again and share the log file with us? This might provide better details on the reason for the error.
Xavier Fortin
[19.02.2025 18:16:08] Devolutions Protocols version: 2025.2.7.1 Windows
[19.02.2025 18:16:08] Terminal font: Courier New [Courier New, fixed=True]
[19.02.2025 18:16:08] Starting SSH, verbose level: 2
[19.02.2025 18:16:08] Setting up connection
[19.02.2025 18:16:08] Connecting to port: 22 (IPv4 - 6)
[19.02.2025 18:16:08] SSH banner: SSH-2.0-IPWorks SSH Daemon 2020
[19.02.2025 18:16:08] Sending kex init
[19.02.2025 18:16:08] Received kex init
[19.02.2025 18:16:08] Selected algorithms: curve25519-sha256, x509v3-sign-rsa, chacha20-poly1305@openssh.com, chacha20-poly1305@openssh.com, implicit by cipher, implicit by cipher, none, none
[19.02.2025 18:16:08] Sending Ed25519 kex init
[19.02.2025 18:16:08] Received Ed25519 kex reply
[19.02.2025 18:16:16] Certificate rejected by system: -2146762487
[19.02.2025 18:16:16] Disconnection in progress
[19.02.2025 18:16:16] Bytes sent: 1848, Bytes received: 2313
[19.02.2025 18:16:16] Packets sent: 2, Packets received: 2
[19.02.2025 18:16:16] Kex completed: 0
[19.02.2025 18:16:16] Pending kex: 1
[19.02.2025 18:16:16] Disconnecting
