WireGuard add-on, start VPN connection without UAC prompt possible?
Resolved
I have setup the WireGuard add-on, and it works fine. I did setup WireGuard to use custom configuration mode, as this is more easy to share with a team.
Is it possible to get rid of the UAC prompt on connect/disconnect VPN? If I start the VPN from the WireGuard client itself, it doesn't need UAC.
RDM version: 2024.3.28.0 64-bit, connected to Devolutions Server
Windows 11 24H2
WireGuard: 0.53.
Kind regards,
Ray
All Comments (5)
Would you be able to provide us with a screenshot of this prompt?
Let me know,
Samuel Dery
It's in Dutch, but it's just a basic uac prompt.
Thank you for following up.
Unfortunately, the only available option is to open RDM in elevated mode, which does not fully address the issue.
I would recommend submitting a request for this feature on our feature request forum.
Apologies for any inconvenience this may cause.
Jacob Lafrenière
Hi Jacob,
I'll do that. It's a bit weird though, because if I start the WireGuard client on my computer, and start the VPN from there, there is no UAC prompt.
It's an issue, because our users don't have local admin rights.
Kind regards,
Ray
I understand how that sounds, and I agree that this should not be triggering a UAC prompt, especially since you do not encounter one outside of RDM.
I apologize for the inconvenience this causes.
Jacob Lafrenière
