Connection Window
Hi all,
I have a question, is there a way to open sections on the right-hand side panel e.g. when i open an RDP it runs the MS RDP client that the session be displayed on the panel to the right. so if I have multiple sessions i can switch between them easily
Would the Thumbnails view be what you are looking for?
https://docs.devolutions.net/rdm/commands/window/layout/
It allows you to have a small view of all open remote connections, or are you looking tmore to have vertical tabs for the connections?
Let me know,
Samuel Dery
Thanks Samuel.
Thank you for your reply,
No problem, I'm glad to see this was what you were looking for!
Samuel Dery
Closed
