Quick connect toolbar disappeared
Resolved
Hi there,
I'm unable to get quick connect toolbar back in any way (even deleting the *.lyt file inside AppData):
I'm using simplified ribbon (but is the same with any other combination). Checked "hide quick connect" option also.
RDM 2024.3.27.0 64-bit
Thanks.
All Comments (2)
You can try to perform a "Reset Layout" to see if the section reappears.
Best Regards,
Michaël Beaudin
Thanks Michaël,
I missed the "quick access..." flag in this window that I tried already.
Solved!
Closed
