Offline setting Local settings.
All Comments (4)
offline issue-onlineoffline issue-offline
Not sure why it accepted the images without allowing me to comment.
The issue is when in Offline Mode I have been able to set the Local Settings for the computer I am on. Since an update within the last 2 months that is no longer possible.
The 2 screenshots are online and offline.
I have looked at all the settings in File->settings and Administration->Vault Setting, Administration->System Settings, Administration->System Permissions, Administration->Security Providers. There are some items which mention Local Setting and they are checked.
Maybe I just missed one somewhere, but don't know where else to look.
Thank you for reaching out to Devolutions Support.
Could you let me know which version you were using before encountering this issue? Currently, it is indeed not possible to modify anything in an entry while in offline mode.
Carl Marien
As of last summer I was able to edit the Local and User settings when I was using RDM on my desktop at home. I'm not sure what version that would be. I do keep up to date when an update is released.
Thank you for your patience.
Could you please review the following blog post about offline mode and ensure everything is correctly set up on your end?
https://blog.devolutions.net/2020/01/offline-mode/
Additionally, if possible, kindly let us know the data source you are currently using. This will help us attempt to recreate the issue on our side.
Carl Marien
Closed
