RDM AD Connection
Hello, how do I set up the AD connection in the RDM MAnager and which login mode do I use for this?
All Comments (1)
I understand that you are currently using Remote Desktop Manager with a SQL Data Source, is that correct?
If so, here is a link to our online help to help you with the authentication method: https://docs.devolutions.net/rdm/kb/how-to-articles/sql-server-datasource-integrated-security/
When creating a new user, make sure to select "Integrated security" beside the username:
