Secure Note: revert to previous entry history not working
Backlog
In a secure note, when we revert to a previous version via entry history, the note isn't reversed.
Indeed, in the compare output, we see that the value of <EncryptedSecureNote> of the previous version (the one we want to revert to) is different then the newest version. But when a revert is done, in then the newest version the value of <EncryptedSecureNote> isn't set like expected (it should be to the entry we choose to revert to).
Please help, thx !
(working in Enterprise version with sql server backend)
All Comments (1)
Hello Erik01,
Thank you for getting in touch with us. To better assist you, could you kindly provide us with the following information:
  • Your current RDM version.
  • The version you are reverting to.
  • The operating system you are using and its version.
  • The data source you are utilizing.
  • Does the note correctly appear when updating but not when reverting?
  • If possible, screenshots showing the issue without showing any sensitive information.
Once we have this information, we will be better equipped to diagnose and resolve the issue.
Maxim Robert
Ends in 7 days
