Problem with RDM and PAM or Plugins
When we link Devolutions PAM accounts to an entry and then try to open it, we always get the following message:
No Connection zur Database, switch to offline mode?
if i use "no" i got this message:
Details:
NullReferenceException - Object reference not set to an instance of an object.
at Devolutions.RemoteDesktopManager.Business.CredentialPAMCredentialResolver.Execute(Connection credConnection, Connection owner, CredentialRepositoryDestination destination, ConnectionEngine engine, CredentialResolveParameters resolveParameters, OpenConnectionParameter openConnectionParameters)
at Devolutions.RemoteDesktopManager.Managers.CredentialTypeManager.GetCredentialResolved(Connection connection, String credentialConnectionID, CredentialRepositoryDestination destination, CredentialResolveMode credentialResolveMode, CredentialResolveParameters resolveParameters, OpenConnectionParameter openConnectionParameters, CredentialsResult credentialsResult)
at Devolutions.RemoteDesktopManager.Managers.CredentialTypeManager.PrepareCredentials(Connection connection, String credentialConnectionID, CredentialRepositoryDestination destination, String privateVaultSearchString, CredentialResolveMode credentialResolveMode, CredentialResolveParameters resolveParameters, OpenConnectionParameter openConnectionParameters, CredentialsResult credentialsResult)
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.Prepare(Connection connection, Boolean applyCredentials, Boolean applyAlternate, Boolean applyVPN, Boolean copy, Boolean applyOverrideCredentials, Boolean isOverrideCredentials, CredentialResolveMode credentialResolveMode, CredentialResolveParameters resolveParameters, OpenConnectionParameter openConnectionParameters, CredentialsResult credentialsResult, Boolean isClosing)
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.OpenConnection(Connection connection, OpenConnectionParameter parameter)
at Devolutions.RemoteDesktopManager.Managers.ConnectionManager.OpenConnections(Connection[] connectionList, OpenConnectionParameter parameter, Boolean isPlaylist)
at Devolutions.RemoteDesktopManager.Managers.ActionManager.DoOpenConnection(Connection[] currentConnections, OpenConnectionParameter openConnectionParameter, IConnectionSource source)
at Devolutions.RemoteDesktopManager.Managers.ActionManager.OpenConnections(Connection[] currentConnections, OpenConnectionMode openConnectionMode, IConnectionSource source, Boolean checkOpenedConnection, ConnectionEngine engine)
at Devolutions.RemoteDesktopManager.Frames.ConnectionViews.FreBaseConnectionView.OpenConnection(Connection[] currentConnections, OpenConnectionMode openConnectionMode)
at Devolutions.RemoteDesktopManager.Frames.ConnectionViews.FreConnectionTreeListView.OpenOnDoubleClick(Boolean isEmbedded)
at Devolutions.RemoteDesktopManager.Frames.ConnectionViews.FreConnectionTreeListView.<>c__DisplayClass241_0.<OnDoubleClick>b__0()
at Devolutions.RemoteDesktopManager.Managers.ThreadManager.PushTimer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(HWND hWnd, MessageId msg, WPARAM wparam, LPARAM lparam)
------------------------ extended stack ------------------------
at Devolutions.RemoteDesktopManager.Forms.FrmErrorMessage.ShowErrorMessage(Exception exception, String message, String title)
at Devolutions.RemoteDesktopManager.Forms.FrmErrorMessage.ShowErrorMessage(Exception exception, String title)
at Devolutions.RemoteDesktopManager.Managers.LogManager.OnThreadException(Object sender, ThreadExceptionEventArgs t)
at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception ex)
at Windows.Win32.PInvoke.DispatchMessage(MSG* lpMsg)
at System.Windows.Forms.Application.ComponentManager.Microsoft.Office.IMsoComponentManager.FPushMessageLoop(UIntPtr dwComponentID, msoloop uReason, Void* pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(msoloop reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(msoloop reason, ApplicationContext context)
at Devolutions.RemoteDesktopManager.Program.Main(String[] args)
We got this message also with Keeper Plugin or BeyonTrust Plugin.
All Comments (7)
Could you update to the latest release of RDM (2024.3.15.0) and see if the issue is resolved? This looks like an error we fixed in that version.
yes sure, let me check this.
i have updated the RDM Manager to the latest version.
Now we got not error with Devolutions PAM.
But with the Keeper Plugin we got this error message:
at Devolutions.RemoteDesktopManager.Forms.FrmSelectKeeperEntry.<>c__DisplayClass47_0.<UpdateRecordsCache>b__0(IKeeperRecord r)
at System.Linq.Enumerable.WhereArrayIterator`1.ToArray()
at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
at System.Linq.OrderedEnumerable`1.ToList()
at Devolutions.RemoteDesktopManager.Forms.FrmSelectKeeperEntry.UpdateRecordsCache()
at Devolutions.RemoteDesktopManager.Forms.FrmSelectKeeperEntry.LoadRecordsInListView()
at Devolutions.RemoteDesktopManager.Forms.FrmSelectKeeperEntry.TxtSearchRecord_TextChangedDelayed(Object sender, EventArgs e)
at Devolutions.RemoteDesktopManager.Controls.DelayedTextBox.OnTextChangedDelayed()
at Devolutions.RemoteDesktopManager.Controls.DelayedTextBox.Timer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at DevExpress.XtraEditors.XtraForm.ShowDialog(IWin32Window owner)
at Devolutions.RemoteDesktopManager.Business.KeeperCredentialResolverConnectionTypeDescriptor.GetCredentialDynamicParameterBrowseResult(VaultOnline vault, IKeeperRecord[] records, String username, String password, Connection credentials)
at Devolutions.RemoteDesktopManager.Business.KeeperCredentialResolverConnectionTypeDescriptor.BrowseDynamicValue(Connection connection, Connection credentials, String credentialDynamicValue, String credentialDynamicDescription)
at Devolutions.RemoteDesktopManager.Managers.CredentialTypeManager.BrowseDynamicValue(Connection connection, Connection credential, String credentialDynamicValue, String credentialDynamicDescription, ConnectionEngine engine)
at Devolutions.RemoteDesktopManager.Forms.FrmConnectionBase.BrowseCredentialDynamicParameter()
at Devolutions.RemoteDesktopManager.Forms.FrmConnection.ButCredentialDynamicParameter_LinkClicked(Object sender, LinkLabelLinkClickedEventArgs e)
at Devolutions.RemoteDesktopManager.Controls.EnhancedLinkLabel.TryClickHyperlink(MouseEventArgs e)
at DevExpress.XtraEditors.LabelControl.OnMouseClick(MouseEventArgs e)
at DevExpress.Utils.Controls.ControlBase.BaseWndProc(Message& m)
at DevExpress.XtraEditors.BaseControl.WndProc(Message& msg)
at Devolutions.RemoteDesktopManager.Managers.ActionManager.EditConnection(IConnectionSource source, ConnectionEngine currentConnectionEngine, ConnectionEngine currentUIEngine)
at Devolutions.RemoteDesktopManager.Managers.SessionMenuManager.MnuEditConnection_Click(Object sender, EventArgs e)
at Devolutions.RemoteDesktopManager.Controls.EnhancedBarButtonItem.OnClick(BarItemLink link)
at DevExpress.XtraBars.BarItemLink.OnLinkClick()
at DevExpress.XtraBars.BarButtonItemLink.OnLinkClick()
at DevExpress.XtraBars.BarButtonItemLink.OnLinkAction(BarLinkAction action, Object actionArgs)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.ClickLink(BarItemLink link)
at DevExpress.XtraBars.ViewInfo.BarSelectionInfo.UnPressLink(BarItemLink link)
at DevExpress.XtraBars.Controls.CustomLinksControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraBars.Controls.CustomPopupBarControl.OnMouseUp(MouseEventArgs e)
at DevExpress.XtraBars.Controls.CustomControl.WndProc(Message& msg)
Thank you for trying this version. I wasn't able to reproduce this issue in our Keeper environment but I will open a ticket so we can fix this. It's probably an empty field in a keeper account that we don't expect.
We weren't able to replicate your issue, but I suspect it has something to do with legacy account types. We pushed a fix that will be available in 2024.3.17.0.
Please let us know if you encounter any more issues.
Jonathan Del Signore
