RDM settings for RDP Session - Full Screen (with smart sizing when tabbed)
Hi
I am missing a setting in RDM, that avoid my RDP sessions initially starting in "Full Screen", I want the resolution to be "Full Screen", but I want it to start out as docked/embedded tab with smart sizing applied.
(and to clarify, I am planning to also have the setting enabled, that ensures my RDP session jumps into full screen, when I double click the embedde session tab)
1st test I did:
When I connect to a new RDP session, it will go into full screen straigt away and I can double tab to dock it into an embedded tab, which then is using smart sizing as expected.
I was hoping to reverse this, so it is smart sizing in the tab at first and I can now double click any tab I wish to go into full screen mode with.
Then i noticed another "Remote desktop size" setting, called "Current Screen Size", which is my 2nd test
2nd test I did:
When I connect to a new RDP session, it will start in en embedded tab, but with large scroll bars, because the resolution is the same an my current screen size, so smart sizing is not applied.
I was hoping that the smart sizing was applied straight away and actually it seems smart sizing doesn't work at all, when using these settings.
Maybe ad an advanced setting in the RDP sesssion settings in RDM, which can force the results I am hoping for, either for 1st or 2nd scenario or even both scenarios?
Michael Leeming
Hello Michael,
Thank you for getting in touch with us.
I've reproduced the issue and confirmed with the development team that this is a bug. I've provided them with all the information, and a ticket was opened. To add more details to the ticket, could you kindly provide us with the following information:
Your current RDM version.
The operating system you are using and its version.
The data source you are utilizing.
I will let you know with more information as soon as possible. If you have any other questions, feel free to let us know.
Maxim Robert
RDM 2024.3.14.0 64-bit
DVLS v2024.3.6.0
Windows 11 23H2
