WinSCP not working with inherited credentials // 2024.3.14.0 64-bit
Since the a couple of RDM updates I have the problem, that WinSCP isn't working anymore with inherited credentials like Linked (vault).
My structure is:
Folder with host information
SSH entry (inherited host + linked creds)
WinSCP subentry (inherited host + inherited creds)
Creds (ssh privat keys for each user)
If I start the WinSCP session, WinSCP wants to start with the ssh privat key password:
Screenshot only in German
If I change the session entry from inherited credentials to custom credentials and set the exactly same ssh key parameters, then WinSCP is working as it should be and as it worked before. I cannot say which update broke the function.
Could someone quickly recreate my structure to check it twice, so maybe the Dev's can create a fix?
Thank you!
Tobi
Hello Tobi,
Could you please specify the version of RDM you are currently using?
What type of data source are you using?
Let me know,
Samuel Dery
Hi Samuel,
Sorry, I put the version in the subject: 2024.3.14.0-64bit Enterprise
As data source we are using MSSQL.
Best Regards,
Tobi
Hello Tobi,
Thank you for your reply,
No problem, I will attempt to reproduce the issue on my end and keep you updated with any news I have,
Samuel Dery
Hi Samuel,
Thank you very much!
Tobi
Hello Tobi,
Thank you for your patience,
I've not been able to reproduce the behavior on my end using the latest version of RDM 2024.3.15.0.
Could you confirm if you're still having the issue after the upgrade?
If you are, can you confirm which option you are using in the "Entry Type" field of the "SSH Key" section of the "WinSCP" entry properties?
Let me know,
Samuel Dery
