Expiring Entries No longer work starting v2024.3.x.x
Good morning.
I was so excited to see this in the release notes for the upgrade I just did to v2024.3.14.0:
  • Added Password list to Expiring Entries in dashboard
However, the whole expiring functionality (especially on the user vault) has seem to have stopped working starting with v2024.3.x.x.
Below are the screenshots from some of the Portable Versions to show you when it was working, versus when it stopped working.
Here is my Expiration configuration to start with:
v2024.2.21.0 (Last Known GOOD Working Version):
Main Vault Config:
User Vault Config:
As you can see in the above screenshots, switching between the Vault and User option works as expected.
v2024.3.10.0 (First Known BAD Version - Every version after this does not work as expected):
Main Vault Config:
User Vault Config:
As you can see in the above screenshots, switching between the Vault and User option does not work as expected.
Please advise...
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.3.2.0 64-Bit - Free
All Comments (6)
Hello Chuck,
After some testing I cannot reproduce the issue in a shared vault but I did reproduce your problem in the user vault.
We will open a ticket for this issue and let you know of any progress.
Best Regards,
Michaël Beaudin
Hello Chuck,
Best Regards,
Good morning, Michael.
My apologies on the confusion.
The Shared vault works as expected = Green highlight
It is just the User Vault that does not = Red highlight.
Glad you were able to reproduce the problem and look forward to the fix.
--- Chuck
The issue with expiring entries not working in the User Vault has been resolved, and the fix will be included in the upcoming release, version 2024.3.15.0.
David Godin
Good morning David.
I see that the display issue is resolved but I am curious about something...
So this looks just the same as it did in previous versions. You don't know what User Vault entries are expiring unless you switch to the user vault, etc. etc. etc.
So, I'm confused in the Release Notes a couple versions ago that restructured this display?
Can you please advise as to what the difference should look like now?
Thanks!
--- Chuck
Hello Chuck,
Could you point out which line in the release notes that you're talking about? I will check what it's directly refering to. It might be badly worded or point to a similar feature instead.
Hello Chuck,
I am unsure as to which release note you are referring to but if we have posted that the user vault's expiring session should be available from the shared vault in 2024.3 then it is a mistake on our end.
What we currently have (internally) is a new widget specifically for that purpose that can be activated in your shared vault's dashboard.
However, this feature will only be available starting from RDM 2025.1. It will look something like this.
Is this what you were referring to?
Best Regards,
Michaël Beaudin
