I've been trying out Remote Desktop Manager for a week or so now, trying to evaluate if it's right for my team. For our Azure servers, I set up a Bastion, and now I'm trying to use that to connect through instead of public IP in RDM.
I successfully set up the Bastion in RDM, and set up one initial VM. That one is working fine. But when I set up any additional VMs (in the same vNet) in RDM, I get this error:
I checked over and over again that the settings on this and the other VM are the same. Is there any reason this might be working for one but not another? Anything I should be checking?
Hello
Sorry to hear about the trouble and for the inconvenience. Internal server error is certainly strange, but I'll need a bit more context to be able to troubleshoot it.
First, I'd like to know which call is failing. If you got to Help > Profiler, and switch to the "Debug Only" tab and set "Debug level" to "1". Then, leaving the profiler window open, try to connect again. I think the log in that profiler window will offer some additional context.
Second, in your Azure Bastion connection settings, what do you have for "Connection mode"? If it's "RD Gateway", please try switching to "TCP Tunnel" and trying again.
Please, let me know if something isn't clear or you have further questions
Kind regards,
Richard Markievicz
I had it set to RD Gateway, so I just changed to TCP Tunnel. Similar results though. Here's what the debug log said (with specifics removed). I'm not seeing anything obvious here though, do you?
Resolved Azure Resource ID: /subscriptions/xxxxxxxxxxxxxxxxxxxxxxxxxx/resourceGroups/xxxxxx/providers/Microsoft.Compute/virtualMachines/xxxxxxxx
[Devolutions.Az][Debug][2024-10-11 08:33:56Z] GET xxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1
[Devolutions.Az][Debug][2024-10-11 08:33:57Z] HTTP/1.1 OK OK
[Devolutions.Az][Debug][2024-10-11 08:33:57Z] AZB Tunnel xxxxxxxxxxxxxxxxxxxxxx to Bastion initializing
[Devolutions.Az][Info][2024-10-11 08:33:57Z] AZB Tunnel xxxxxxxxxxxxxxxxxxxxxx listening at 127.0.0.1:42172
OpenVPN: Result is Not Null
OpenVPN: Calling AfterVPNOpen
OpenVPN: Returning result
rdpClientAdvancedSettings4.AuthenticationLevel:0
rdpClientAdvancedSettings6.EnableCredSspSupport:True
[Devolutions.Az][Debug][2024-10-11 08:33:57Z] AZB Tunnel xxxxxxxxxxxxxxxxxxxxxx client connected
[Devolutions.Az][Debug][2024-10-11 08:33:57Z] POST xxxxxxxxxxxxxxxxxxxxxx HTTP/1.1
[Devolutions.Az][Debug][2024-10-11 08:33:57Z] HTTP/1.1 Forbidden
[Devolutions.Az][Debug][2024-10-11 08:33:57Z] System.AggregateException: One or more errors occurred. (Exception of type 'Devolutions.Az.AzHttpException' was thrown.)
---> Devolutions.Az.AzHttpException: Exception of type 'Devolutions.Az.AzHttpException' was thrown.
at Devolutions.Az.Utilities.EnsureSuccessStatusCode(HttpResponseMessage response, HttpStatusCode[] extraSuccessCodes, String resourceId)
at Devolutions.Az.Utilities.EnsureSuccessStatusCode(HttpResponseMessage response, String resourceId)
at Devolutions.Az.Bastion.Client.CreateTunnelAuthToken(Host bastionHost, VirtualMachine virtualMachine, Int32 remotePort, TunnelAuthToken authToken, CancellationToken cancellationToken)
at Devolutions.Az.Bastion.BaseWebSocketConnection.Connect(CancellationToken cancellationToken)
at Devolutions.Az.Bastion.ClientWebSocketConnection.Connect(CancellationToken cancellationToken)
--- End of inner exception stack trace ---
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at System.Threading.Tasks.Task.Wait()
at Devolutions.Az.Bastion.WebSocketProxy.OnAcceptTcpClient(IAsyncResult ar)
Hello
Thanks for the information. Here's what's happening: before we can open the websocket to the Bastion, we need to request an auth token based on the resource you're connecting to, the protocol, port as well as your OAuth token from the Azure login. That call is returning is 403 ("Forbidden") so this indicates an issue with authentication.
It is possible that something has changed on the Azure side, and it wouldn't be the first time we see such a change affect only a subset of users (Azure tend to roll out updates and changes across different regions on different schedules).
However - I'm not sure that's the case - you wrote above that the connection to the initial VM works, but subsequent connections (to other VMs) fail. Perhaps you can try a test for me: if you close RDM and relaunch it (to ensure we have a cold credential cache), does the first connection work regardless of the host you connect to? So, start from cold, and connect to a VM that isn't the initial VM you mention above. Does it work? But then any other VM fails in this manner? What about that initial VM? Are you able to reconnect to it?
Please, let me know if something isn't' clear or you have additional questions; and sorry for the inconvenience
Kind regards,
Richard Markievicz
So the first VM that's working, it seems I can connect to that regardless. Any other VMs don't work though, even after re-opening. So regardless of the order of connect, the one VM works and the others don't. Though I can launch Bastion for all of those other VMs through the Azure Portal with no problem.
I just ran the debug again with both the working and non-working connections and this seems to be the line of difference:
working VM:
[Devolutions.Az][Debug][2024-10-11 09:11:05Z] AZB Tunnel xxxxxxxx client connected
[Devolutions.Az][Debug][2024-10-11 09:11:05Z] POST xxxxxxxxxxxxxxxxx HTTP/1.1
[Devolutions.Az][Debug][2024-10-11 09:11:06Z] HTTP/1.1 OK
non-working VM:
[Devolutions.Az][Debug][2024-10-11 09:10:35Z] AZB Tunnel xxxxxxxxxxxxxxxxx client connected
[Devolutions.Az][Debug][2024-10-11 09:10:35Z] POST xxxxxxxxxxxxxxxxx HTTP/1.1
[Devolutions.Az][Debug][2024-10-11 09:10:36Z] HTTP/1.1 Forbidden
[Devolutions.Az][Debug][2024-10-11 09:10:36Z] System.AggregateException: One or more errors occurred. (Exception of type 'Devolutions.Az.AzHttpException' was thrown.)
Hello
Thanks for the information! So, we have a problem caching the OAuth token from the initial Azure login. I'm surprised because this hasn't been reported by anyone else, so I need to figure out what's special in this case.
Can you please share the full configuration of the Azure Bastion in RDM? The general and authentication settings; obviously obfuscating any sensitive information. You can also send to me by PM if you prefer.
Do the VMs exist in the same subscription and resource group as the Bastion?
Do you have multiple Azure tenants associated with your login?
Please, let me know if something isn't clear or you have other questions
Kind regards,
Richard Markievicz
That gave me an idea and I think I figured it out somewhat. I'm able to connect to VMs in the same resource group as the Bastion with no problem.
The other VMs, some are in the same vNet, some in other vNets that have a peering. But they're all in different resource groups from the Bastion.
I didn't realize the resource group mattered if there was a vNet peering... is there a way for it to connect to other resource groups?
