Specify Default Vault For AD Group?
several of our departments use RDM for accessing different vault.
Is there a possibility to specify a default vault for a specific Active Directory group (so that the vault is always opened at first)?
Data Source: DVLS
Best regards
All Comments (5)
Hello an33,
Thank you for reaching out to the Devolutions Support team.
Only one default can be configured, and a default cannot be configured for a group of users.
What could be done is to change the default vault to one that will be used by most of your users and change the visibility of the other vaults.
Also, when you close RDM and re-open it, the last vault will be saved as the default opening.
https://docs.devolutions.net/hub/web-interface/administration/management/vaults/set-vault-default/
https://docs.devolutions.net/server/web-interface/vault-access/
Patrick Ouimet
Hi Patrick,
thank you for your fast response and the links.
Then, the configuration via RDM would be the way to go for us.
We are forcing a standard config after every reboot - would it be possible to specify a default vault in the RDM config file?
Then, we could create a default config file for every department.
Best regards
Hello An33,
Thank you for this feedback.
If you are on an RDS environment, the best way to force a config file for your users, is to change the Default.cfg file under the installation path.
This is an article on it:
https://docs.devolutions.net/rdm/installation/client/terminal-services/
Patrick Ouimet
yes, we are already capable to force a specific config.
The question would be if it is possible to specify a default vault in the config file?
Best regards
Hello An33,
I see nothing related to the default vault in the configuration file.
Maybe it is configured in the database.
Patrick Ouimet
Closed
