Switching Vaults Causes Script Dashboard Navigation to Turn Gray, Requiring Reopen
A fix for this issue has been implemented in version 2025.2.27.0
When you switch the vault while the Script Dashboard is open, the navigation on the dashboard turns gray, requiring you to close and reopen it.
Windows 23H2
Remote Desktop Manager Licensed 2024.2.19.0
Datasource: Azure SQL
All Comments (2)
Thank you for bringing this to our attention. We'll open a ticket to investigate the possibility of doing a proper refresh instead of disabling everything.
We'll keep you updated on the progress.
Jonathan Del Signore
A fix for this issue has been implemented and will be available in version 2025.2.27.0.
Closed
