I am trying to set the Default Syncrhonzer settings for the VMRC here:
I want the following settings to automatically populate when I run a VMWare Syncrhonizer (image, and blue boxed):
However, even though I have those set, I see the below:
The only other way I have been doing it is by setting up an Entry Template which does in fact carry the settings. HOWEVER!!!!!
If you apply the Entry Template either after (Edit > Special Actions > Template > Convert), or by specifying a template in the VMWare Synchronizer, it does NOT populate the host or VM id, so it leaves the entry useless.
If the latter of the two are the appropriate way to do it, would you please investigate and fix the issue with not populating the host or VM id?
Thanks!
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.3.16.0 64-Bit - Free
Hello Chuck,
Thank you for contacting the Devolutions support team.
I have tried it on the latest version, 2024.2.20.0.
All the settings from the template created are applied by using the convert to the template as a batch edit.
Have you tried it with the 2024.2 or 2022 version on SQL?
Patrick Ouimet
Hello Chuck,
I am on SQL Server 2022.
Yes, the options do in fact populate. BUT, you will lose the vmID that is stored, and whatever host is stored when you do the convert with template.
--- Chuck
Hello Chuck,
Thank you for this feedback.
Could you try this with 2024.2 with the local data source and see if this issue still occurs?
An export of some of your entries + a new template could be enough to have an accurate result.
Patrick Ouimet
