RDM 2024.2.20 terminates when using SSH Secure Gateway with MS Edge browser
Hi everyone,
I'm trying to access multiple different web interfaces from e.g. Proxmox Virtual Environment and Portainer using RDM over a SSH Secure Gateway. While that works for MS Edge as chosen browser, that combination terminates the whole app pretty often. Either when browsing the sites after a few minutes or when closing the tab of the site or... I didn't find any one reliable trigger currently.
Changing to Chrome isn't that easy, because for some reason the SSH Secure Gateway setup doesn't work the same way. With Edge, the URLs seems to be automatically changed as necessary to pass the SSH tunnel. With Chrome that isn't the case and I need to manually create the and maintain the tunnels, which is a tedious work with multiple different web apps at the same host. Additionally, that shouldn't be necessary at all in theory, because Edge and Chrome share a lot of the same codebase. I've already tried multiple settings with Chrome and proxy as well, but nothing worked. The only thing working is creating a SSH tunnel manually for each endpoint of interest.
So, I would like to keep the MS Edge-setup as it's easier to maintain, but the app crashes are very annoying. Would be great if one could have a look at why they happen. Thanks!
Name der fehlerhaften Anwendung: RemoteDesktopManager.exe, Version: 2024.2.20.0, Zeitstempel: 0x66960000
Name des fehlerhaften Moduls: ntdll.dll, Version: 10.0.19041.4522, Zeitstempel: 0x8a1bb6f3
Ausnahmecode: 0xc0000374
Fehleroffset: 0x00000000000ff439
ID des fehlerhaften Prozesses: 0xbf4
Startzeit der fehlerhaften Anwendung: 0x01daf8866f7643d7
Pfad der fehlerhaften Anwendung: C:\Program Files\Devolutions\Remote Desktop Manager\RemoteDesktopManager.exe
Pfad des fehlerhaften Moduls: C:\WINDOWS\SYSTEM32\ntdll.dll
Berichtskennung: e022c9ef-f4f8-4295-b33d-672c3f34fd93
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
Fehlerbucket 1530581340542995482, Typ 4
Ereignisname: APPCRASH
Antwort: Nicht verfügbar
CAB-Datei-ID: 0
Problemsignatur:
P1: RemoteDesktopManager.exe
P2: 2024.2.20.0
P3: 66960000
P4: StackHash_aeac
P5: 10.0.19041.4522
P6: 8a1bb6f3
P7: c0000374
P8: PCH_8B_FROM_ntdll+0x000000000009E0B4
P9:
P10:
Angefügte Dateien:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERAF10.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB8F5.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB934.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB932.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERB952.tmp.txt
Diese Dateien befinden sich möglicherweise hier:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_RemoteDesktopMan_fba09be9e6aa635cd62e12a7bb26ec9be36c68f_9fb652f9_40c58233-1cfa-407b-a8bb-a2d6af8f0a80
Analysesymbol:
Es wird erneut nach einer Lösung gesucht: 0
Berichts-ID: e022c9ef-f4f8-4295-b33d-672c3f34fd93
Berichtstatus: 268435456
Bucket mit Hash: 04ad82d68c882dbc853db79eaee80c1a
CAB-Datei-Guid: 0
The following stacktrace is available only sometimes:
Application: RemoteDesktopManager.exe
CoreCLR Version: 8.0.824.36612
.NET Version: 8.0.8
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Stack:
at DevExpress.Utils.Taskbar.Core.ICustomDestinationList.BeginList(UInt32 ByRef, System.Guid ByRef, System.Object ByRef)
at DevExpress.Utils.Taskbar.Core.JumpListInternal.Refresh(DevExpress.Utils.Taskbar.Core.JumpListKnownCategoryPosition)
at DevExpress.Utils.Taskbar.Core.JumpListInternal.Refresh()
at DevExpress.Utils.Taskbar.TaskbarAssistant.OnJumpListChanged(Boolean)
at DevExpress.Utils.Taskbar.TaskbarAssistant.OnParentControlActivated(System.Object, System.EventArgs)
at DevExpress.XtraBars.Ribbon.RibbonForm.OnActivated(System.EventArgs)
at Devolutions.RemoteDesktopManager.Forms.FrmMainDocumentManager.OnActivated(System.EventArgs)
at System.Windows.Forms.Form.set_Active(Boolean)
at System.Windows.Forms.Form.WmActivate(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.Form.WndProc(System.Windows.Forms.Message ByRef)
at DevExpress.XtraEditors.XtraForm.WndProc(System.Windows.Forms.Message ByRef)
at DevExpress.XtraBars.Ribbon.RibbonForm.WndProc(System.Windows.Forms.Message ByRef)
at Devolutions.RemoteDesktopManager.Forms.FrmMainDocumentManager.WndProc(System.Windows.Forms.Message ByRef)
at System.Windows.Forms.NativeWindow.Callback(Windows.Win32.Foundation.HWND, Windows.Win32.MessageId, Windows.Win32.Foundation.WPARAM, Windows.Win32.Foundation.LPARAM)
at System.Windows.Forms.NativeWindow.DefWndProc(System.Windows.Forms.Message ByRef)
at DevExpress.Utils.Taskbar.Core.FilterWindow.WndProc(System.Windows.Forms.Message ByRef)
at Windows.Win32.PInvoke.PeekMessage(Windows.Win32.UI.WindowsAndMessaging.MSG*, Windows.Win32.Foundation.HWND, UInt32, UInt32, Windows.Win32.UI.WindowsAndMessaging.PEEK_MESSAGE_REMOVE_TYPE)
at System.Windows.Forms.Application+ComponentManager.Microsoft.Office.IMsoComponentManager.FPushMessageLoop(UIntPtr, Microsoft.Office.msoloop, Void*)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoopInner(Microsoft.Office.msoloop, System.Windows.Forms.ApplicationContext)
at System.Windows.Forms.Application+ThreadContext.RunMessageLoop(Microsoft.Office.msoloop, System.Windows.Forms.ApplicationContext)
at Devolutions.RemoteDesktopManager.Program.Main(System.String[])
Hello pickwick81,
Thank you for contacting the Devolutions support team.
It seems that this issue is related to your .NET framework. Please try redownloading it and select the repair option using the following link:
https://dotnet.microsoft.com/en-us/download/dotnet/thank-you/runtime-8.0.8-windows-x64-installer
Additionally, please ensure that your Webview2 is up to date by visiting the following link:
https://developer.microsoft.com/en-us/microsoft-edge/webview2/
Please let me know if Remote Desktop Manager (RDM) continues to crash after applying these fixes.
Patrick Ouimet
Yes, it still crashes regularly and the stacktrace makes pretty much clear that there's a memory corruption problem in the app which needs to be debugged.
Thank you for this swift reply.
Could you send a Minidump file of this issue.
You can use the secure link below to send us the file;
https://devolutions.sharefile.com/filedrop
Simply name your file “FRM-42759” to easily identify it.
Patrick Ouimet
Done. I've started RDM, opened a connection with MS Edge and SSH Secure Gateway and didn't do anything else, because I don't know when the app crashes. So no idea if you see anything useful without me triggering the actual issue, but In don't know what that is, so... :-)
Hello pickwick81,
According to your other forum thread and the screenshot you shared,
Could you switch the ports from the source to the destination and tell me what happened?
Patrick Ouimet
I don't get your point, the other thread is for totally different settings with Chrome instead of Edge, totally different problem. If you want to debug that one, then please answer in that thread, I don't see how your instructions here have anything to to with the crash. Here Edge + SSH Secure Gateway are working until the app crashes, no need to change any settings.
Hello pickwick81,
Sorry for the confusion, but for me, it's the same issue.
You mentioned having an issue with both browsers passing through an SSH gateway.
Can you tell me if this is the same Gateway?
Does this issue occur outside of RDM?
Have you sent the minidump?
Patrick Ouimet
It's not: MS Edge through SSH Secure Gateway crashes the app at some random point with the stacktrace I've posted. Google Chrome instead doesn't work at all through SSH Secure Gateway because of some internal setup issues and/or problems with proxy handling. What is done under the hood for MS Edge and works there isn't done for Google Chrome (anymore). The difference is that with Google Chrome there's no connection possible at all through SSH Secure Gateway/proxy and the app does not crash.-
Two totally different und totally unrelated problems.
Yes, so I strongly suggest you focus on debugging that and the app crash in this thread.
Sorry for the late response.
I'm working hard to reproduce this issue and investigate this behaviour.
I'll let you know when we will have an outcome.
Patrick Ouimet
Would it be possible for you to create a portable installation of the latest version of RDM and see if this issue still occurs? To do so, you will need to do the following:
(Close RDM)
4- Go to this folder once the .zip file has been extracted and run remotedesktopmanager.exe
5- Connect to your data source
Patrick Ouimet
Still crashes:
Application: RemoteDesktopManager_x64.exe
.NET Version: 8.0.8
Description: The process was terminated due to an internal error in the .NET Runtime at IP 0x00007FFCF8541B5C (0x00007FFCF8530000) with exit code 0x80131506.
Name der fehlerhaften Anwendung: RemoteDesktopManager_x64.exe, Version: 2024.2.21.0, Zeitstempel: 0x66960000
Name des fehlerhaften Moduls: coreclr.dll, Version: 8.0.824.36612, Zeitstempel: 0x6696b815
Ausnahmecode: 0xc0000005
Fehleroffset: 0x0000000000011b5c
ID des fehlerhaften Prozesses: 0x40f4
Startzeit der fehlerhaften Anwendung: 0x01daffccf64bcc35
Pfad der fehlerhaften Anwendung: C:\Users\tschoening\Downloads\Devolutions.RemoteDesktopManager.Bin.2024.2.21.0\RemoteDesktopManager_x64.exe
Pfad des fehlerhaften Moduls: C:\Program Files\dotnet\shared\Microsoft.NETCore.App\8.0.8\coreclr.dll
Berichtskennung: 26aac117-ef70-4fe1-ae09-ec6ff4a01dde
Fehlerbucket 2288332117829734273, Typ 4
CAB-Datei-ID: 0
Problemsignatur:
P1: RemoteDesktopManager_x64.exe
P2: 2024.2.21.0
P3: 66960000
P4: coreclr.dll
P5: 8.0.824.36612
P6: 6696b815
P7: c0000005
P8: 0000000000011b5c
P9:
P10:
Angefügte Dateien:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER6736.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER77A2.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER77E2.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER77EF.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER7800.tmp.txt
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_RemoteDesktopMan_2fee298bb1d316cc29a35098ee44af7e3fc9e04d_05bfd4fa_6ec76ee9-83b7-4c2c-8137-2297005453f8
Analysesymbol:
Berichts-ID: 26aac117-ef70-4fe1-ae09-ec6ff4a01dde
Bucket mit Hash: 722b32423642c238cfc1c9efe35bcf81
CAB-Datei-Guid: 0
Hello pickwick81,
I sent you an email to investigate further.
Patrick Ouimet
