Entries missing/ moved around after computer restart (RDM/Devolutions Password Manager)
I just restarted my computer and now inside of my RDM one folder is completely empty and all of the sub folders and entries are in the main vault. I thought maybe I had accidentally dragged them out but when I attempt to move one in I get an error for a circular reference. I then opened workspace to see if the entries were messed up there as well; instead of being messed up they seem to be completely hidden I can only tell because I have a historical event from 4 days ago and can access it that way. Any help or information would be greatly appreciated.
UPDATE: When I sign in to check the entries on the web portal, the folder is marked as Unhealthy, I assume this is an issue on Devolutions side as nothing has changed today, nor have I even accessed that particular folder today.
Hello Adam,
Thank you for contacting us regarding this,
Could you please specify the version of RDM/Workspace you are currently using?
What type of data source are you using? Am I correct in assuming this is Hub Business?
Let me know
Samuel Dery
I am using a Hub Personal and I am on version 2024.2.17.0 64-bit.
I have the same entry in a business Hub and it was fine on that end.
Please note that I was thankfully able to restore them to the initial import from months ago and it seems fine at this point. But would Still like to know what happened if possible.
