Intune installl and uninstall command for RemoteDesktopManager.exe
What are the install and uninstall commands to deploy RemoteDesktopManager.exe (version: 2024.1.27.0 )in Intune as a Win32 app?
Hello
I believe the answer depends on what you're packaging. Did you create your .intunewin from the RDM .msi, the .exe or some other way?
Please let me know if something isn't clear
Thanks and kind regards,
Richard Markievicz
I created from the RemoteDesktopManager.exe to the .intunewin file with the Microsoft-Win32-Content-Prep-Tool-master. I already find and succesfully tested the install command "RemoteDesktopManager.exe /quiet /norestart". Can you tell me in my situation what the uninstall command is?
