Resolved
Add an entry for SMB opening
Hi to my favourite support team and product đź’™
I was wondering if it is possible to add an "Open Folder" item as new data entry.
What i want is like i have RDP and VNC to have an entry once i double click it to open the "\\servername\c$\myplace"
or the "j:\technical\isos" in a new windows explorer window
Is this possible ?
Thanks !
-Vassilis
RDM for Windows 11
Purchased Enterprise Edition v2026.x
Hello Vassilis,
You could look into the "SMB (server message block)" entry or "File explorer", I think they should work for your case. Let us know if this works for you!
Hello Vassilis,
Yeap! i didn't see the file explorer entry, SMB is not working as wanted but File explorer is perfect.
Thank you !!!
RDM for Windows 11
Glad to hear it, let us know if you encounter anything else!
