clipboard and new connections problems
Hello!
I accidentaly posted this in the IOS forum before, but i'm having a weird problem.
I recently downloaded this to try it out, but i'm suspecting im missing something? There is no option to add a new session. I can quick connect, but if i want to save it i have to create it in another program and then import it. That dosnt sound right? What i mean is that under the "new entry" options, there is no option for "new connection".
Same with clipboard. From what i can gather, you are supposed to be able to copy / paste betwen the host and the RDP session. But again, there is no clipboard option. I've reinstalled it multiple times but i guess the features just dont excist? Or am i doing somethign wrong that i cant seem to find an aswer to?
I'm running version 2024.2.7.4 for macbook.
All Comments (7)
You should be able to add connections to a datasource. When you download Remote Desktop Manager, you should follow the startup wizard.
Which datasource mode did you choose: local or online?
Here is how it should look and how to add an entry on a fresh install:
Jesse Galarneau
