problems with new connections and clipboard.
Hello!
I recently downloaded this to try it out, but i'm suspecting im missing something? There is no option to add a new session. I can quick connect, but if i want to save it i have to create it in another program and then import it. That dosnt sound right? What i mean is that under the "new entry" options, there is no option for "new connection".
Same with clipboard. From what i can gather, you are supposed to be able to copy / paste betwen the host and the RDP session. But again, there is no clipboard option. I've reinstalled it multiple times but i guess the features just dont excist? Or am i doing somethign wrong that i cant seem to find an aswer to?
I'm running version 2024.2.7.4 for macbook.
All Comments (2)
Thank you for reaching out.
This thread is for the iOS version of the app. However, your issue seems to be about the Mac version. Could you confirm that?
Best Regards,
Frederick Simard
hello! Yes that’s correct. Sorry I messread the IOS part.
