Delay With Session Tab Switching Using Personal Hub
Resolved
Hoping someone can shed some light on what is going on here.
I am using Devolutions hub personal with RDM 2024.2.13.0 and there seems to be some kind of delay when opening or switching sessions using this data source. I understand the data source is not local so I expect a delay when opening a session saved in the data source, but the issue I am running into is that every time I switch tabs between open sessions, there is a ~1 second delay and the loading window briefly pops up.
I've been dealing with it for a while but its slowing me down just enough that I'm considering switching back to the SQLLite database.
Is there any sort of local caching or some setting I am missing here that would prevent this behavior?
All Comments (2)
Hello iangrahamit,
Thank you for reaching out to the Devolutions support team.
In that case, would it be possible for you to create a portable installation of the latest version of RDM and see if this issue still occurs? To do so, you will need to do the following:
(Close RDM)
4- Go to this folder once the .zip file has been extracted and run remotedesktopmanager.exe
5- Connect to your data source
This test will allow us to rule out your local installation of RDM as a possible cause for this issue.
If this is not resolved, could you send a recording of this issue and explain the process in detail?
You can use the secure link below to send us the recording(s);
https://devolutions.sharefile.com/filedrop
Simply name your file “FM-42339” to easily identify it.
Patrick Ouimet
Thanks Patrick, I did use the portable installation and it didn't have the same issues. I uninstalled my version (and cleared app data) and then reinstalled and that seemed to do the trick.
Not sure what the issue was but glad it's resolved.
Thanks!
