Good morning.
Is there a way within RDM to set a custom color for specific entries?
I messed around with the "Color" setting for a single entry, but that is for connection itself, and not the listing.
We have numerous different VPN's that we need to connect to, and it would be nice if I could differentiate which connection on which VPN by entry color.
Thanks!
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.3.16.0 64-Bit - Free
This is not something supported. It's not really easy with the current architecture, but I will try to think of a way to implement this. I can't promise anything, though.
David,
Thank you for the upfront response. I didn't think there was a way to do that from what I could tell, but figured I would give it a shot.
Maybe something to the affect of color always equals default, unless something like <NameColor> field is populated?
Of course that would be a new field, but just throwing something out there.
Thank you again, sir.
--- Chuck
This is much easier than what I thought if it's the text and not the image.
Absolutely sir! Just the text!!!
Exactly the same thing as when I set a Jump Host the text turns green.
Just want to have the customer's ability to set the text to certain colors to help other teammates differentiate between the VPN's needed for connectivity.
Yellow = VPN 1
Blue = VPN 2
Green = Jump Host
That kind of stuff, sir.
--- Chuck
I have created a ticket for that.
I was looking at this and found that this is already supported:
