how to connect with ssh shell then launch command to use tail ...
I made a SSH SHELL connexion to my server.
it works fine.
Now I try to automatically use a command after login and I don't find how to do it.
The command : tail -fn 1000 /xxx/log/yyy/catalina.out
I tried to add my command in Event > After Open
but then I have : unable to execute the command line [#tail"] with argument [-fn 1000 /xxx/log/yyy/catalina.out
is it possible to automatically use a command after login ?
I don't find where to put it
Which RDM version are you using?
Instead of the Event section, add the command in the Post login section, located in General
Min
hello,
i'm using version 2023.3.39.0 64-bit
I already tried to add a command in "post login" as seen below but when I launch my shell, nothing happens, it just open a "ssh shell" (picture 2).
What do I do wrong ?
Please remove the data in Expected Prompt:
Min
wow thank you!
it works.
regards,
