Aruba Switches login not working
I have set up a browser session (Google)for
login on an Aruba switch. Credentials are corret. Login don't work. If I open a
local browser session the login works. Browser session in RDM doesn't.
Any ideas?
Regards, Sasha
All Comments (5)
Thank you for reaching out to Devolutions Support.
Please refer to this documentation to manually set up the HTML control:
https://docs.devolutions.net/workspace/kb/website-authentication/#method-1
If you have any additional questions, concerns, or require further support, please let me know, and I'll be more than happy to help.
Carl Marien
Hi Carl
That's not wha i meant. All that login stuff works perfectly, all the fields are filled correctrly but after "sending" tho login command nothing happens. It will delete the entries and just stay on that page. if i click on "fill the autologin information...", same thing, Information is filled correctrly but after the "Login" nothing happens.
Regards, Sasha
Thank you for the clarification. Would it be possible to send us a video of the issue?
I have sent you a link to safely send the video through email.
Carl Marien
Video is uploaded
Regards, Sasha
Thank you for the video. As I mentioned in the case you have with us, there are some cases where the website entry doesn't work with a website. These issues usually appear on internal websites inside of protected switches or routers, and this issue seems to be related to that, unfortunately.
The only workaround would be to set the entry to external and use our plugin to push the credentials.
Carl Marien
Closed
