Troubles with VNC connection to Raspbery Pi
Recently after update we got problems with VNC connection.
Before update everything was ok, no problems.
RDM version 2024.1.32.0
All Comments (30)
Hello
I'm sorry for the inconvenience. This was caused by a regression introduced when we updated a cryptographic dependency, which broke certain authentication functions.
This is already fixed for the upcoming 2024.2 release which will be next week.
I'm afraid I don't have a workaround or back port of the fix for 2024.1, which means the only solution until updating is to rollback to the previous version that worked.
Please, let me know if you have any questions or comments
Kind regards,
Richard Markievicz
Thank you for this information I think we wait for update.
After update to version 2024.2.8.0 everything works just fine. Thank you for your help.
Hello
Good news! Thanks for the update and please don't hesitate with further questions or comments.
Kind regards,
Richard Markievicz
The bug is still present in the Android version of RDM 2024.2.0.16 (latest version in the Google Play Store).
Last functional version I've tested with explicit apk installation: 2024.1.6.1
When is the bugfix planned for the android version?
Kind regards,
Roland
Hi Roland
Sorry for the inconvenience. I'm checking with the Android team which version of our VNC integration they're currently using, it's almost certain that they just need to update on their side to fix this. That should be a quick fix; it's a public holiday today in Quebec (where the team is based) so it might be a day or two before I have an answer on that. I do appreciate your patience.
In the meantime please don't hesitate with further questions or comments
Thanks and kind regards,
Richard Markievicz
Hi Richard,
many thanks for your efforts. Do you have an answer from the colleagues according to the release date for the android bugfix app already?
Kind regards,
Roland
Hello
I've raised the issue with them, I'll post back once I have an update. Thank you for your patience!
Kind regards,
Richard Markievicz
There is still no fix available ...
Is it a question or a statement? The latest version should have a fix for this issue. Are you on the latest version?
Carl Marien
