My internet has occasional hiccups and I never assume it's the ISP, and opt to check my hardware first. However, if I don't have RDM open at the time that the internet drops, it will not load any of my connections or credentials. This leaves me with 2 questions:
1) Is there a configuration to allow me to keep all of this information locally so that I don't have this problem?
2) Can I export my connections and credentials in a way that I can move them to another platform as a backup.
Hello Rtuite81,
Regarding your first question, could you please provide us with the information below?
Your current RDM version.
The operating system you are using and its version.
The data source you are utilizing.
Once we have this information, we will be better equipped to provide you with the right steps.
You can also export your sessions and credentials by navigating to "File" > "Export" and choosing your preferred format, such as CSV or XML. This allows you to back up your configurations or migrate them to another platform.
Here's a helpful topic regarding the Export option in RDM.
https://docs.devolutions.net/rdm/commands/file/export/
If you have any other questions, feel free to let us know.
Maxim Robert
