Recordings Display in RDM - "Session Name" ; request for same level of detail as in the "Connection" field in RDM Activity Log
Good evening all!,
We are using basically what I think is called Devolutions Template groups, where there is a hierarchy between, for example, an SSH device, and a Web device which use the same password. So the child inherits the PW from the parent. Unfortunately in our case we have large numbers of these devices in our Vaults, and the children do not have detailed names, but just "WEB" for example, as they are all listed under the parent which is given the descriptive name.
This is working fine for reporting - Activity Log and other areas, but is almost no value in the "Recordings" tab within each vault, as there may be dozens of identical names within the Vaults. e.g., you will see for example WEB repeated, with no indication as to which parent it is tied to.
If we could get the same information for those children Sessions in the Recordings tab as we have over in the Activity Log, that would provide great benefit. It looks like it is the same source data in both areas of RDM, but the Activity Log also aggregates the parent data to make a very useful field display for "Connection".
With regards, Phil Lyons
