Implemented
Navigation pane question
Hi
I updated to 2024.1.30.0 and now every time I open RDM afresh, my Navigation tree is completely collapsed.
This didn't happen in previous versions, and I didn't change any settings. I prefer my tree expanded by default, so which setting controls this? I've tried a couple and they made no difference
All Comments (6)
This issue was reported in the following thread: https://forum.devolutions.net/topics/42052/collapsed-tree
From our testing, it should be fixed in our upcoming minor version, 2024.1.31.0. I can't give you an estimate on when we will release this version, but we are shooting for next week. For now, the only workaround is to revert back to 2024.1.29.0 which doesn't have this issue.
Hello Hubert,
I saw that minor version update 31 was available, and installed it. It has not resolved the issue of the tree being collapsed each time I start the program.
Thank you for the feedback, we will reopen the ticket on our end and see if we can find the source of this issue.
Confirming I also experience this issue in 2024.1.31.0 64-bit
We've found and fixed the issue, this should take effect for both the upcoming 2024.1 and 2024.2 versions.
Jafran Majeau
Thank you - installed v.32 and confirm it is resolved for me.
