Hello. Lonnnnng time user, amazing product.
Im trying to figure out something, I just cant seem to figure out. We use an ssh jumphost, if I setup ..\.ssh\config to use a jumphost like this:
PS C:\Users\me\.ssh> cat .\config
Host jump.foo.bar
IdentityFile C:\Users\me\.ssh\id_rsa
User me
Host !jump.foo.bar *
ProxyJump jump.foo.bar
User me
ForwardAgent yes
I can use powershell and connect directly to any host and MFA doesnt pop up. How can I emulate this in RDM? Ive set the following,
but every single time I launch a session I get prompted for MFA (albeit it does directly connect to the host). I just can't deal with an MFA request to every single session.
Thank you for using our products Could you please attempt setting up a Powershell entry in RDM to replicate the SSH command you typically use in your PowerShel?
This could give us more insight into whether this method effectively bypasses the repeated MFA requests or if further adjustments are needed within the RDM settings or the SSH configuration itself.
Please let me know how it goes.
Carl Marien
I created a simple Powershell command entry, with a command of ssh me@host.com and it opened up powershell and connected without MFA.
I would like to see your issue firsthand. Would it be possible to have a remote session with you?
Carl Marien
Yes of course. I am CDT and around from 9am to 3pm M-F. It could just be that I am not setting up jumphosts correctly, or missing some sort of setting. But Ive spent hours trying to figure it out.
Just let me know when.
I have created a ticket and will shortly send you a link to request a session.
Carl Marien
Thank you for the session where you explain your issue where Each connection to the jump host requires MFA approval via your phone, which is cumbersome.
as said in the session I will contact the developers about your issue.
Carl Marien
Hello, just checking in to see if there has been any updates on this?
