DASHBOARD not sync when datasource goes automatically OFFLINE
Hello
when data source goes in offline mode, the dashboard show data and action not syncronized with the current item selected in the treeview.
It show actions of the last element selected before switch to off line.
Example: the item selected doesn't show the correct actions for the type of item. It show lates item selected before offline.
I have opened a ticket to investigate the issue you reported.
Gabriel Dufresne
The issue should be solved in the latest version of RDM Mac (2024.2.7.3)
If there's anything, don't hesitate to communicate with us.
Michel Lambert
