Enable usage of credentials. Entry opened with parameters
If we open, for example, an HTTP entry, passing with right click > open with parameters > select credentials, those credentials are not usuable anywhere, they're not copied nor listed, so it is a bit "useless" (just for this especific scenario). Refer to support case 00059656.
Is there any other way to achieve this? Or shall it be checked by development team?
Thank you, best regards.
All Comments (1)
As mentioned in the support case, this behavior is not currently supported and there are no workaround.
We will monitor this thread for further feedback from our community to help us prioritize this request.
