Trying to connect to a Extreme Switch via Console cable from a Macbook air with only USB-C
Hi everyone,
So I am trying to connect to a Extreme switch 5952GTS, with a Macbook air M2 with only USB-C, I am able to now get the console cable working. But I am having trying to get the serial terminal to work with my MAC. So I have it working, but I would like to get this working in "Remote Desktop Manager".
The speeds I am using are the following:
Baud rate: 9600
Data bits: 8
Stop bit: 1
Parity: None
Flow control: XON/XOF
When I test this on Serial 2, this work without any issues. But when I try with the same settings on "Remote Desktop Manager" I am having issues and I can see text, but looks like wrong speeds. I read somewhere someone talking about "Type" I need to change something. But I am not sure.
I also saw another article but can't find it again. Talking about activating vt100/ansi , is this possible im "Remote Desktop
Has anyone done this or can help out that would be great.
Below are some references just in case other are interested.
Reference:
Extreme Switch Speeds reference: https://extreme-networks.my.site.com/ExtrArticleDetail?n=000018604
Connect via Mac Terminal: https://extreme-networks.my.site.com/ExtrArticleDetail?an=000080386
USB-C to Serial cable DB9 RS-232 (https://www.delock.com/produkt/62964/merkmale.html?g=1015)
CoolTerm (works a little, but problems ) (https://freeware.the-meiers.org/)
Serial 2 (Works, but don't want to pay the $40 for old tech with Serial ) (https://www.decisivetactics.com/products/serial/)
We are going to investigate into the issue and the options you talk about
and come back to you.
In the meantime, if there's anything, don't hesitate to communciate with us.
Michel Lambert
