VNC connection opens Auth window even if this is not required
Implemented
I have some connections that do not require authentication (username and password), I configured the Credentials to None
And when I connect to the VNC it requires the authentication
Is there any setting that I can enable to avoid this VNC Login window?
All Comments (5)
I don’t believe it is possible. Can you confirm that the connection works properly when you click "Connect"?
Carl Marien
It works fine but it is a little bit annoying to click on connect for each VNC connection that don't require a user and password
Unfortunately, this feature is currently not supported. However, I will add this forum thread to the feature request forum so our developers can take a look at it. In the meantime, you will need to continue clicking on connect for each VNC connection that doesn't require a user and password.
Carl Marien
We have opened an internal ticket for this, as it should be possible to improve the behavior. We will post back here once we have an update.
Hello
This was fixed and I'd encourage you to try with the latest RDM version (2024.1.28). Please let us know if you have any questions or further feedback.
Kind regards,
Richard Markievicz
