Mouse Cursor not changing when hovering over window border.
Implemented
When I hover over a window border, the mouse icon doesn't change to the 'double arrow' icon. I can guesstimate where I need to be to move/change a window size (and that does work), but it's just difficult to tell if I'm pointing in the right place. Works correctly on my windows versions of RDM, just not on my Mac.
RDM OSX ver. 2024.1.6.2
Sonoma 14.4.1
Just reporting this, not a request for follow up.
All Comments (5)
I see, I'm assuming this is with an RDP Connection? Could you confirm if this is working for you without issues when connecting to your host outside RDM?
I'm also wondering if this was working as expected in a previous version? If so, do you remember the version number?
Let me know,
Samuel Dery
Hello
Just following up on what my colleague wrote, I'm aware that this is a known issue and under investigation on our side. I'll add this forum post to the ticket and we'll update you once there is some news.
Thanks and kind regards,
Richard Markievicz
Just in case other stumble upon this post like I did.
I found that the last working version that showed the mouse cursor changing for resizing, hyperlinks, etc was 2023.3.13.4.
The interesting thing about this is that between 2023.3.13.4 and 2024.1.5.1 the dmg file size went down by roughly 50mb.
Hopefully this helps someone else.
Hello
This has been fixed internally and should be in an imminent release.
Thanks for your patience
Kind regards,
Richard Markievicz
Our latest version of RDM Mac (2024.1.8.6) is out
and the issues with the cursor should have been solved.
If there's anything else, don't hesitate to communicate with us.
Michel Lambert
