Copy to Clipboard using Variables
Anyway to use a variable in the Copy to clipboard field? Currently it copies the plain text inside the field and ignores the variable.
All Comments (2)
Which RDM version and data source are you using?
It is necessary to enable in the Security Settings section the Allow Password in variable option. (If you're using a linked the credential entry the setting must be enabled on this entry as well)
https://docs.devolutions.net/kb/remote-desktop-manager/troubleshooting-articles/unable-use-password-variable
Min
On your session, Security Settings tab, check Allow password in variable
Stéfane Lavergne
Closed
