Misleading CreatedBy and ChangedBy values
Resolved
Hi
we noticed some misleading values for Last Changed By and
Created By on entries.
If a user starts RDM client, the value will always be the current
logged on user from the Windows system, no matter what user actually will be
used for making changes.
Example:
User A is logged on to a workstation, but uses another user (eq A_Admin) for
the tasks he wants to do in RDM.
The Value in the logs will always be User A, which is
misleading because this user does not have the rights to perform these actions.
It should be logged correctly, that the changes were made by
A_Admin.
This problem does not occur if the user works via browser. However, there could be more than the CreatedBY and CChangedBy values which are misleading.
All Comments (2)
Hello Markus,
I assume this setting (located at System Settings) covers your request:
Min
You are correct. Thanks!
