Vault order in Remote Desktop Manager
Implemented
Since the last update to version 2024.1.x, vaults no longer appear in the same order between Devolutions Server and Remote Desktop Manager. These are classified in Alphabetical order under Devolutions Server, but in Remote Desktop manager the default vault appears first, and therefore the classification is no longer in Alphabetical order. Is it possible to fix this, or to have a feature that allows vaults to be categorized in RDM? Or change the default vault Maybe..
Thanks
All Comments (4)
We've tested this and it looks like RDM is the one that changed, but it wasn't an intentional change. We will open a ticket to fix this, and post back here once we have made the change.
We have also moved your thread to the RDM bug report board.
Hello, ok thanks for your feedback.
This issue has been fixed internally and will be available in version 2024.1.23.0.
Jonathan Del Signore
I just tested version 2024.1.23.0 and it works, thank you very much!
