Checking System in the Required Information of a System Information Report entry causes it to fail
Backlog
When I enable the 'system' option in a System Information Report entry, the report generation fails after a few minutes. The target system is a Windows Server 2022 VM. It works fine with all the other options enabled.
Please let me know if you would like any additional info.
Thanks
Joe
All Comments (12)
Hello Joe,
  • Could you please specify the version of RDM you are currently using?
  • What type of data source are you using?
Was this working without issues for you previously?
I'm also wondering if you have any additional details of this error under "Help" -> "Application Logs"?
Let me know,
Samuel Dery
Hi Samuel,
Using v 2024.1.18.0 with DVLS data source.
I didn't attempt to use this feature until current version, so not sure if it worked previously. However the 'Load from system information' button on the entries Asset\Networking page does work fine.
Nothing is shown under Help\Application Logs for when the inventory fails.
Joe
Hello Joe,
Thank you for this feedback.
Since this is a tool from an entry, could you tell me if your management tool credentials are set with an admin account?
Are these credentials linked to the vault or set as username passwords?
Patrick Ouimet
Hi Patrick,
Management Tools credential is set to 'use default credentials'. Changing to to 'use session credentials' makes no difference, which are an explicity defined admin account on the entries main property page.
Joe
Hello Joe,
Our quality assurance team was able to reproduce this issue on our side.
An internal ticket regarding this issue is open.
I'll keep you posted here on any progress.
Patrick Ouimet
Great, thanks Patrick
Hi Patrick,
Any progress on this one yet?
Thanks
Joe
Hello Joe,
Unfortunately, I don't know when this will be fixed and which version will be used.
I'll let you know as soon as a fixed version is available.
Patrick Ouimet
