Having to disable/enable OpenVPN TAP adapter to open subsequent connections in RDM
I recently have started to have an issue, within the last week or two, where I'm having to disable/enable the OpenVPN TAP adapter in Windows 11 to allow RDM to open up any new connections. Anyone else having a similar issue? This seems to be new. I'm not sure if the problem is with OpenVPN or the way RDM is sending commands to the latest release of OpenVPN so I'm starting here.
I've found that if I right click / exit the OpenVPN icon instead of RDM closing OpenVPN, it doesn't exhibit this behavior.
We will have a fix for this issue in version 2024.1.20.0. If you want to make it work in the meantime, you could run RDM as an administrator.
Jonathan Del Signore
Thank you.
Closed
