Session shortcut as sub-entry (issue or by design ?)
I have created a shortcut to a session which I would like to use as a sub-entry. The problem is that when I move the link under the parent session, it is transformed into a real session and deleted from the original folder.
Is this a bug or by design?
Attached an animated gif.
thanks in advance
Best regards
Davide
All Comments (2)
This is a limitation of our current shortcut/sub-entry feature, at the moment it's not possible to have a shortcut of a sub-entry, because the folder for the sub-entry is always the same as its parent.
We will keep this in mind as a possible improvement for the shortcut/sub-entry features, but it's not a very simple change.
With that in mind, I have moved your thread to the feature request forum, so we can better keep track of our community's feedback regarding this functionality, as this is part of what helps us prioritize feature.
Hello Hubert,
thank you for quick response.
Davide
