The input string '0+38eda72778eaabe450d8b21b1acc5969d778efde' was not in a correct format
System.FormatException: The input string '0+38eda72778eaabe450d8b21b1acc5969d778efde' was not in a correct format.
at System.Number.ThrowFormatException[TChar](ReadOnlySpan`1 value)
at System.Version.ParseVersion(ReadOnlySpan`1 input, Boolean throwOnFailure)
at System.Version.Parse(String input)
at System.Version..ctor(String version)
at Devolutions.RemoteDesktopManager.Managers.DevolutionsHubPersonalLegacyDataSourceManager.SetVersion(Guid dataSourceID)
at Devolutions.RemoteDesktopManager.Managers.DevolutionsHubPersonalLegacyDataSourceManager.ConnectFromDeviceKey(HubPersonalConnectionDataSource dataSource)
at Devolutions.RemoteDesktopManager.Business.DataSources.HubPersonalLegacyWebAuthentication.Login()
at Devolutions.RemoteDesktopManager.Business.DataSources.HubPersonalConnectionDataSource.Login()
A fix for this issue is coming soon.
Side notes:
  • This issue concerns only Hub Personal data sources that aren't updated. You can update your Hub Personal by going on https://hub.devolutions.com.
  • Hub Personal legacy data sources are going read-only with recent updates
Aymeric Jala
Hello Atapin,
The fix Aymeric is referring to is now available.
Can you navigate to https://hub.devolutions.com and let us know if the behaviour is corrected?
Marc-Antoine Dubois
Marc-Antoine Dubois
Thank you! You helped me!
Closed
