SFTP Issue on RDM 2024.1.15.0 64-bit
Implemented
The SFTP session locks up and will not exit via the x in the session tab or via "Close All other Tabs" option. I'm only able to end the sessions via Task Manager. I'm able to replicate issue on already established SFTP sessions and new SFTP sessions. All other connection modes seem to be working as intended. If I open an SSH session into a machine and then open an SFTP session I'm able to close that SFTP & SSH session w/o an issue. I'm using the SFTP session with a padlock on it per provided image.
Hello Felix,
Our QA department has been able to reproduce this behavior, we've opened a case with ou development team and have linked it to your thread.
We will keep you updated with any news we receive,
Let me know if you have further questions,
Samuel Dery
Hello!
After several days with the same problem, and reinstalling the application, even trying on several different computers, the problem persists,
Whenever I close a tab of a SFTP connection, the program " crashes ", and I have to end it from the task manager,
I'm "glad" to know that I'm not the only one with this problem, and that the development team is already working on a solution,
If you need any information, do not hesitate to ask for it,
nbeauregard
Disabled
Hello Eduardo,
This issue has been fixed and will be available in the next release.
Thank you for your feedback.
Nathan Beauregard
