Error: Microsoft edge can't read and write to its data directory
Hello Support,
I run latest RDM 2024.1.15 as admin and have this error when I tried to update the powershell script.
Can you advice?
Thank you.
Would it be possible for you to create a portable installation of the latest version of RDM and see if this issue still occurs? To do so, you will need to do the following:
4- Go to this folder once the .zip file has been extracted and run remotedesktopmanager.exe
5- Connect to your data source
If the issues persist with the portable installation, could you follow this knowledge base article and make sure WebView2 is installed correctly:
Let me know,
Samuel Dery
