Is there any way to implement the same type of auto logoff for FreeRDP entries like you have for standard RDP entries?
--- Chuck
Overgaard, AZ (-7 MST / Zulu Year-Round)
RDM Version: 2026.3.2.0 64-Bit - Free
Hello Chuck,
We will see what we can do. I have opened a ticket.
Good morning, Hubert.
I was curious to get an update on this to see if there's any plans for implementation in a near future release?
Thanks!
--- Chuck
At the moment we don't have an estimate.
Is this blocking for you? I was also curious, is there a reason you're using FreeRDP over the regular RDP integration if you're using the Windows version of RDM?
There are a handful of servers where I need to force TLS v1.2 connection.
This is an option in FreeRDP, where in MSTSC you cannot force a TLS connection version.
The option to select which TLS version you connect with in FreeRDP was added back before 2023.3.39.0 from a ticket I opened and was implemented.
--- Chuck
Thanks for the information. I'll check with our team if we can prioritize this feature then.
