Issue #1:
Window layout does not persist. Every time I launch RDM I have to reset the window layout in order to get the quick launch, navigation panel, search bar, etc.. to appear.
Issue #2:
Smart folders no longer return results. Double clicking on the folder does nothing. I can edit the properties and change the entry name and/or add tags but it doesn't do anything.
Issue #1 has been present for me for at least the last three version of RDM. Issue #2 I did not discover until today.
I am running RDM 2023.3.39.0, using DPS as the data source (release 2023.3.14.0).
Hello Grant,
Could you confirm if you encounter the same issue with a portable version of RDM?
To do so, you will need to do the following:
4- Go to this folder once the .zip file has been extracted and run remotedesktopmanager.exe
5- Connect to your data source
Let me know,
Samuel Dery
I tested the portable version this morning and did not experience the same issues. The window layout persists as expected and smart folders are populating the matching sessions.
I assume this means my local install is corrupt in some fashion. Are there any particular steps I should follow if I want to fully remove the client and reinstall it?
Thank you for reaching out to us.
To address your concern, we will reset the configuration of the Remote Desktop Manager. Please follow the steps given below to reset it:
1. Close Remote Desktop Manager.
2. Go to the following directory: %localappdata%\Devolutions
3. Rename the RemoteDesktopManager folder to RemoteDesktopManager.old.
4. Launch RDM again.
Please note that resetting the configuration will remove all your data source information, and you must enter it again.
Let us know if you have any further queries or concerns. We are always here to help you.
Maxim Robert
Unfortunately, this did not work. I did not have any issue reconnecting to our data source, but the same problems I listed above came back. Window layout does not persist if I close and re-open the app (literally, the interface is blank when I open RDM), and smart folder no longer. However, I now believe the issue with smart folders is related to the windows layout. I had forgotten that the smart folder contents are displayed in the Dashboard tab, and that tab is also gone. I tried toggling it on/off in the Window menu but it did not do anything.
The portable version is working just fine so I am going to continue working off of that for now.
Hello Grant02,
Thank you for your response!
Could you try the steps below and tell me if the problem still occurs?
Thank you for letting me know.
Maxim Robert
Apologies for the late reply. I think I am more or less back to normal now. I ended up removing the client and making sure all files were deleted from Program Files and AppData before reinstalling. No issues for the last couple of days.
Thanks for your help.
Hello Grant02,
Thank you for the feedback!
I'm glad to hear that the problem didn't occur for the last couple of days.
If the problem comes back or if you have any other questions, don't hesitate to contact us.
Maxim Robert
