Question - If a session times out and locks, is there a quick way to sign back in?
If a session in RDM times out and locks and requires reentry of password, is there a way to do that with the press of a button rather than manually entering the password?
All Comments (1)
ylecouedic
Disabled
Hi rossmuron,
I have some questions about the issue:
1- What version of RDM are you running?
2- What type of data source are you using?
3- What type of session are you launching?
4- Are you launching the session in embedded or external mode?
5- Do you receive an error message?
6- If possible, send some screenshots that will help us to have a better understanding of the issue.
