Is there an option to set the subentry to follow the color specified for the (parent) entry? Namely, it turns out that I have to manually and individually for each subentry change the default color according to the color of the parent entry.
Best Regards,
Ljubomir Manojlovic
Currently, RDM does not offer the feature. However, we are open to adding it, although we cannot commit to a specific ETA for its implementation. To proceed, we need additional details about how you want this feature to function.
We propose two implementation methods:
Introducing a setting in the app's preferences. When activated, this option would ensure that whenever an entry is assigned a parent, its color automatically updates to match the parent's color.
Alternatively, we could add a new option in the context menu (accessible by right-clicking on a parent entry). This would allow you to select an option to synchronize the colors of all child entries with their parent.
Please let us know which approach you would prefer.
Jesse Galarneau
I'm glad you agree with the suggestion/idea. I think there should be both, as they are not fundamentally the same settings.
Namely, the method under 1 is normal to exist, as something that is the initial setting of the application and the possibility to always set a "system rule".
At the same time, the method under 2, would be a convenient setting for the so-called "per case" settings (it should not change the "system rule").
Best Regards,
Ljubomir Manojlovic
I have created a ticket for that. We also have another user who would like to inherit the icon as well. I think that the best solution would be to have a setting per entry with Default in the vault. It could be
Sub connection icon: Default, Parent Image and Parent Color
Agree 100%.
Have a nice day.
Best Regards,
Ljubomir Manojlovic
